Forums >> Revit Building >> Technical Support >> Profile Parameter
Mon, Mar 9, 2009 at 2:38:40 PM | Profile Parameter
JRMello
This may be one for the wishlist, because Ican't find anything about it. Does anyone know how to make a sweep profile in a family parametric so you could, for example, change a door casing profile in the project without editing the family?
Mon, Mar 9, 2009 at 2:44:54 PM | Profile Parameter
The stock REVIT door has that already in it.  .... but I think it's an extrusion and not a sweep - either way, it can be done.
Mon, Mar 9, 2009 at 3:04:27 PM | Profile Parameter
JRMello
I don't mean change rectangular casing dimensions, I mean change the moulding profile from one to another. If that's in the Imperial default Door, I'm missing something.
Mon, Mar 9, 2009 at 4:06:26 PM | Profile Parameter
Sorry but you did say parametric ... what you say now is completely different.
The question now is can you pass a parameter to the family that will allow for multiple -sub families.  You can establish these using visibility parameters ... but beyond a couple that would be a problem and the profile would have to be in the family.
Another user mflure thinks he has a solution for this but I have not yet seen it.
Wed, Apr 28, 2010 at 11:15:54 AM | Profile Parameter
FlawlessCowboy
I just wrote up a Tips & Tricks post for this, after wrestling with this last night. Hopefully it helps you out.
 http://www.revitcity.com/forums.php?action=viewthread&thread_id=20298
Using a profile parameter to define a sweep profile
Fri, Jul 19, 2013 at 9:31:17 AM
making a profile a parameter
Fri, Apr 15, 2011 at 10:25:56 AM
adjustable profile family
Fri, Jul 20, 2012 at 9:08:25 AM
Shared profile
Wed, Nov 11, 2009 at 9:40:38 AM
How can I make a parametric Profile?
Thu, Nov 11, 2010 at 11:40:59 AM
Page generation time: 3.5651
