Forums >> Revit Structure >> Technical Support >> Stair Handrails and View Range
Mon, Mar 9, 2009 at 2:37:22 PM | Stair Handrails and View Range
yvonnezh
This is a pretty standard egress stair. The handrails at the wall side is not continuous - so we have extensions at the start and end run by run. Since it is a "U" shaped stair, the middle run is usually cut by the view range. The strange thing is the wall handrail extensions do not show in the plan (they are shown correctly in sections). And I tried to cut the stair at the landing, it does not work. Has anybody had this problem before? The attached PDFs are for two different view ranges. For view range from 6'-2' to 6'-8" the stair cutline basically the same. The cutline jumps to the third run if view range is higher than 6-9" and the same problem transfers to my third run handrail.
Rvt 2013 Handrails for 3-run stair
Wed, Apr 5, 2017 at 1:59:55 PM
STAIR HANDRAILS
Mon, Dec 13, 2010 at 8:50:19 AM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
Revit 2013 Stairs/Handrails
Thu, Feb 14, 2013 at 7:27:18 PM
Non-continuous handrails at stairs
Thu, Jan 25, 2018 at 11:34:45 AM
Page generation time: 6.2676
