Forums >> Revit Building >> Technical Support >> Wall Openings
Mon, Mar 9, 2009 at 10:30:23 AM | Wall Openings
joeinck
Greetings,
I am having troubles with Wall openings. Specifically, I created a simple wall and added a tile wall sweep 1200mm high (with base and bullnose top). I then inserted a wall opening (selected from modeling; opening; wall opening) in a wall between my kitchen and dining room to act as a pass thru (pretty typical). Well the opening does not cut the wall sweeps. Can anyone help me with this? I like the wall sweeps idea and need to keep that, i just want them to be cut by my wall opening (not a door or window opening).
thanks
Mon, Mar 9, 2009 at 11:16:01 AM | Wall Openings
tim123
4 Stars: 19 Votes
Make sure that the wall opening extends to the bottom of the sweep and it should cut it.
Mon, Mar 9, 2009 at 11:28:14 AM | Wall Openings
joeinck
can not extend the wall opening to the bottom of the sweep, as that would create an opening from the finished floor. A pass thru window starts at the top of a typical counter top, did i understand you correctly?
thanks
Mon, Mar 9, 2009 at 11:43:35 AM | Wall Openings
tim123
4 Stars: 19 Votes
Yes you did.  If the opening does not extend to the bottom of the sweep you may have a problem (it needs to be at least half I think).  You could perhaps try two sweeps of 600mm each.  Alternatively, I would suggest a more elegant solution of including the tiling as a wall layer, which you can unlock and stretch down to the relevant height.
Mon, Mar 9, 2009 at 12:50:33 PM | Wall Openings
wheelergc
You could also edit the Profile i think. That should work
Mon, Mar 9, 2009 at 1:14:14 PM | Wall Openings
joeinck
i think i will try the wall layer idea as i have never used that and it sounds easy. i dont think that i can edit the wall profile as it would not be a closed loop when i finish; the opening is a "hole" in the wall, not connected to its edges if that makes sense.
thanks for you help folks,
Mon, Mar 9, 2009 at 1:49:02 PM | Wall Openings
Edit profile will still work.  It does not have to connect to the edge of the wall so it works well for holes.  As a matter of fact - it works well on curtain walls to - try it - you'll like it!
Mon, Mar 9, 2009 at 2:40:22 PM | Wall Openings
joeinck
Thanks, i will give ideas a try....
Curved wall openings
Fri, Oct 15, 2010 at 12:42:11 AM
Coordination review with wall openings
Tue, Sep 18, 2007 at 8:57:20 AM
Exclude wall openings and windows etc from wall schedule
Tue, Nov 12, 2013 at 4:46:24 AM
OPenings through multiple walls?
Mon, May 24, 2010 at 4:48:54 PM
Wall openings not showing in linked model
Thu, Mar 15, 2018 at 2:07:06 PM
Page generation time: 0.5245
