Forums >> Revit Building >> Technical Support >> Stair problems
Sun, Mar 8, 2009 at 2:38:51 PM | Stair problems
bharris
Why do the stairs add the last riser 1" back of the stringer?  It extends into the floor assembly now which is not what i want.
I want the riser/stringer ending flush to they can hook onto the floor assembly.
Thanks
Sun, Mar 8, 2009 at 3:10:54 PM | Stair problems
bharris
I want it to able to do what the poster in this thread asked...
 http://revitcity.com/forums.php?action=viewthread&thread_id=8107
Mon, Mar 9, 2009 at 4:45:16 AM | Stair problems
tim123
4 Stars: 19 Votes
Extend the stair boundaries the required amount to adjust the stringer end position.
Mon, Mar 9, 2009 at 9:33:11 AM | Stair problems
bharris
I can get the risers/stringers flush and it looks right in section, but now there is a gap in plan?
Mon, Mar 9, 2009 at 12:00:51 PM | Stair problems
tim123
4 Stars: 19 Votes
Revit does not show the risers in plan, but in real life the floor in your view would be treated as the top tread.  The top tread should have the same conditions and profile as the other treads, so would you not need a nosing detail at the edge of the floor here?  If so. this would overcome your problem.
Precast stair with notch connection
Fri, Aug 26, 2016 at 1:05:15 AM
Stair problems! Stair problems!
Mon, Mar 20, 2006 at 4:42:22 PM
Problems witha amonolithic stair
Wed, May 23, 2007 at 2:15:41 PM
modifying stair problems...
Wed, Oct 24, 2012 at 4:47:13 PM
Align stair pattern in 2d
Wed, Jul 4, 2018 at 5:16:20 AM
Page generation time: 0.6744
