Forums >> Community >> Newbies >> draping street edge onto toposurface
Fri, Mar 6, 2009 at 7:36:55 PM | draping street edge onto toposurface
rierie
Hi, I downloaded street edge file from GIS to CAD, but it's flat, and does not have height associated with it. Is there a way to drape the street edge lines onto toposurface so that the street edges would be visible in the ground floor plan? At this point, I'm not worried about curves, I just want to show where the street is on the topo.
Thanks always for your help!
Mon, Mar 16, 2009 at 10:09:16 AM | draping street edge onto toposurface
Berryjiveuptown5
Not sure if this is the best way to do this or not, but here's a theory:  try and load your linework from GIS and then in a plan view, break up the topography with the Split Surface (if that doesn't work, try the Subregion) Tool, tracing the linework of the streets.   When you are finished, your roads will actually be a different topo surface which you can apply a different material to, and they will be correct in plan and elevation.
Hope this helps!
Mon, Mar 16, 2009 at 4:48:03 PM | draping street edge onto toposurface
rierie
Thank you! Subregion seem to work the best!
Sloped Toposurface for Street
Thu, Dec 20, 2007 at 6:33:02 PM
Toposurface edge
Sun, Oct 16, 2005 at 6:24:28 PM
build road and street
Tue, Oct 15, 2013 at 11:36:30 PM
External street lights
Mon, Jun 6, 2011 at 12:11:52 PM
sidewalk split topo suface issues
Fri, Oct 7, 2005 at 5:11:42 PM
Page generation time: 0.6000
