11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Dimension problem
50 Posts No Rating |
Anyone has an idea why I am not able to dimension an angled wall, see screen shot. You will see that I was able to dimension the wall on the right but the left side is giving me problems, I keep cycling thru to select the right wall points as I did with the wall on the right but no success.
Cycle through two times to get the point on the corner and it should dimension. The first time it will select the point that is orthagonal, the second time it selects the point aligned to the wall.
Got it thank so much Tim123
Dimension Text Problem |
Fri, Nov 14, 2008 at 9:41:55 PM
Problems importing .dwg details! Text gets scrambled in sneeky ways! Help! |
Thu, May 10, 2007 at 10:06:45 AM
Dimension String Doesn't Equal Overall Dimension |
Wed, May 27, 2009 at 2:33:49 PM
temporary dimension disappearing when converting it to permanent dimension |
Thu, Sep 14, 2017 at 9:48:30 AM
Dimension problem... |
Wed, Oct 22, 2008 at 4:40:50 AM
