11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> distorted lines in camera
19 Posts No Rating |
Hi everyone I have a problem regards with the camera because as i take a shots and streching the box the displayed lines were distorted and it is not good for perspective
Move your camera back - you may need to hide elements to do this. Stretching the box is like creatin a wider angle lens and will distort the perpective.
thanks for the reply can u pls post here if there is a proper way on using camera so that lines should not be distorted thanks
As soon as you start stretching the box the perspective is distorting although a small amount wont make much difference. Compare the two views - the left hand image shows the camera much too close and is distorting the perspective.
Thanks for the great info I see there is a quite difference but is there a way that we can eliminate those distorted lines? or do we have other option or method so that we can create great perspective without distorted lines thanks again tim
Camera lens adjustment |
Sat, Sep 9, 2006 at 12:03:58 PM
Camera View not showing demolition lines dashed |
Wed, Dec 11, 2013 at 2:24:15 PM
Distorted Perspective |
Wed, May 21, 2008 at 11:08:56 AM
Camera-Icon interactive placed with camera |
Thu, Sep 3, 2009 at 10:57:30 AM
Can't create camera or walkthrough on first floor but can on others. Why? |
Wed, Nov 19, 2014 at 10:32:39 AM
