26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> curved curtain wall
31 Posts No Rating |
Hello when I make a curved curtain wall of 180 degrees, and add mullions, I find that the end mullions do not line up to 180 degrees
How do i make them do this
cc
that is because the curtain wall is not perpendicular to the 180d line,which is wierd... try and create a curtain grid as close as you can to the edge, not perfect but close
Post edited on 2005-06-23 02:18:25
28 Posts No Rating |
It may also be because the mullions are placed on the grid at their centerline. Another way to correct this would be to create a new mullion type and have it place the mullion by the edge, not the center.
Vanessa
Actually,
Just to clarify, edge mullions (mullions to the exterior edges of the wall) are placed by the exterior side so as not to modify the size of your wall. This is why your experiencing the problem. The other mullions in between this are placed at there centrelines. Solution would be to break the 180º into segments that allow you to have your mullions in the correct places...
curved angled curtain walling |
Wed, Mar 8, 2006 at 4:18:50 AM
curved curtain wall, straight transoms, curved panels |
Tue, May 12, 2015 at 8:36:03 PM
curved curtain system -diagonal grid system? |
Wed, Feb 11, 2009 at 4:24:47 PM
curved curtain wall |
Sun, May 12, 2013 at 1:54:01 PM
curtain walls |
Sun, Dec 7, 2014 at 9:29:54 PM
