Forums >> Revit Building >> Technical Support >> Project North & True North
Wed, Mar 4, 2009 at 4:34:19 PM | Project North & True North
Needwiz
Needwiz Avatar
I am puzzled by using the true and project north. I created a 2d site plan in autocad with the true north pointing to the upper side of my monitor, showing where the main entrance of the house will be located (see screen shot Ture North). To make the house entry face me I rotated the drawing with true north arrow pointing the lower side of my monitor (see screen shot Project North). I imported the dwg in RA2009, see screen shot, now the issue is that the norht in RA2009 is opposite to north of the imported dwg.
Does anyone knows how to change the north elevation in RA2009 to be the south, and the east elevation to be the west? Can I rotate them?
54415_True_North.JPG54415_Project_North.JPG54415_Import_Link_Cad_Format_in_RA2009.JPG
Wed, Mar 4, 2009 at 7:21:32 PM | Project North & True North
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi Needwiz, have you checked the topic in the Revit Help section?....
Thu, Mar 5, 2009 at 3:59:50 PM | Project North & True North
Needwiz
Needwiz Avatar
I follow the help menu tutorial but it is very subtle at least to me. I missing some steps and is just frustrating me.
I need to maintain the project north for correct solar studies. So I inserted a linked dwg file w/ north pointing stright up.
So the dwg link has the true north at 90 degrees just like when I create a new project in revit the north is at 90 deg. The issue is that the walls are angled with respect to the north and I want to make the walls orthogonal and the north to be the south (rotated at 180) how do I keep this true north and project north coordinated?Please see attached screen shot.
Thu, Mar 5, 2009 at 4:55:36 PM | Project North & True North
eldados
eldados Avatar
4.5 Stars: 8 Votes
Needwiz,
you always, always work in project north, that means that your project is perpendicular to your view, it will make life much easier when documenting.
At any stage you can rotate to True North, I have attached a little tutorial I hope will help clear things out Smile (need flash player)
By the way, there's also Magnetic North which is in a different location every year, but that's another discussion altogether Winking
Integrator
KarelCAD
Thu, Mar 5, 2009 at 5:02:49 PM | Project North & True North
Needwiz
Needwiz Avatar
Guys thank for all your help. I after spending four hours of trouble shooting finally got it.
For people who are new with RA2009 don't be fooled with the imported link that was the issue for me. when I was rotating the true norht the link was not rotating with it and that complicated what I was trying to accomplish and also after trying and trying some of us get more confused....SO TAKE A BREAK AND START FRESH.
Ask for help and search the forum under under true north there is a good link to a video that someone posted. I will paste the link here but for some reason is not working so search for it.
Attached are screen shot so you can have an idea of what I had to go through.
54502_Angle_of_rotation.JPG54502_Floor_Plan_Project_North.JPG54502_Link_needs_rotation.JPG54502_Site_True_North.JPG
Project North doesn't rotate back after changed to True North
Fri, May 7, 2010 at 3:24:14 AM
True North vs Project North Linked dwgs
Thu, Mar 10, 2016 at 10:02:26 AM
project north/true north
Thu, Mar 17, 2005 at 5:00:19 PM
True North / Project North spelled out
Sun, Jun 10, 2012 at 1:41:04 PM
EXPORTING TO FBX TO TRUE NORTH
Wed, Sep 9, 2015 at 7:36:58 AM
Page generation time: 1.8250
