21 Users Online (19 Members):
Forums >> Community >> Newbies >> Still trying to figure out families
8 Posts No Rating |
I am still somewhat new to revit and i am trying to figure out more about families. What is the difference between Type and instance? Is type when i want to use it in multiple drawings and instance is when i just want it custom for that drawing. Please Let me know.
When you setup new parameters in a family you are asked to select type or instance, instance allows you to change the parameter at will if you chose type you would have to go back to the family editor.
mbsteve was not quite right. Instance parameters are just that ... an instance. You can set it or change it any time for that one instance. Types can be established in the family editor but they can also be created in the project. Type parameters are used across multiple instances of the same type. As an example.... a door of the type 3'-0" .... if set correctly, all doors of that type would be 3'-0"... If you edited the type and changed the type parameter to = 3'-6" ... all doors of the type 3'-0" would now be 3'6".
Edited on: Wed, Mar 4, 2009 at 11:28:09 AM
Revit Families Privacy??? |
Wed, May 4, 2011 at 8:25:57 AM
Can't figure out PDF printing. Help! |
Tue, Sep 12, 2006 at 4:39:07 PM
Calculating cost of Nested Families in families in projects - Custom Kitchens |
Wed, Nov 13, 2013 at 4:09:28 PM
10 New REVIT 8.1 'Families' Video Tutorials released |
Tue, Oct 2, 2007 at 12:39:43 PM
I cannot figure out how to model this piece... |
Mon, Jan 23, 2012 at 4:14:45 PM
