13 Users Online (11 Members):
Forums >> Revit Structure >> Technical Support >> System Family:Surface
4 Posts No Rating |
Hi, newbie here, and I am stuck. I need to add a few surfaces as toposurface, but I cannot seem to load any or create new ones from the default. I am therefore stuck as I cannot seam to get more than on surface type ie If I change the defaut to grass all my topo surfaces are grass. Where am I going wrong? is there somewhere to load surfaces from? Thanks in advance
From the site menu, you can split the face of the topo.... when you do that, you can assign a different surface for the split area's properties.
12 Posts No Rating |
I'm a little unclear as to how you have built the surfaces. Did you create different toposurfaces, or did you make one surface with subregions. Typically yuo would want to create the whole topo, and then use subregions to divide it into the different surface types. You can then change the type property for each subregion to whatever material you need. You should be able to do this even if you created multiple topos because the material is a type property. This is different from the Site Settings menu from the dropdown toolbar. This controls what the cut material is, and is constant regardless of what material you apply to the topo from the properties menus. Check the tutorial, it's pretty clear on the steps you should follow.
4 Posts No Rating |
Many thanks for this, I had created one topo and split it, but didnt seem to be able to apply different surfaces. But thanks to your help I am now ok.
4 Posts No Rating |
In addition how do I get my topo surface to appear with a thickness in rendering, so it covers footings etc.
You can try in that view, in VP activate the "Section box" then move the blue arrows until you get what you want, this is one way two do this...
voronoi surface pattern |
Fri, Jun 24, 2011 at 2:14:03 PM
New System Family |
Wed, Jan 25, 2012 at 9:27:12 AM
Help dividing surface of imported .sat file to create curtain system |
Sat, Nov 13, 2010 at 12:44:51 PM
System Family Names |
Wed, Sep 9, 2009 at 10:32:42 AM
Nested Families and System Parameters |
Fri, May 8, 2015 at 9:47:41 AM
