Forums >> Revit Systems >> Technical Support >> Objects not showing in "fine" detail level
Tue, Mar 3, 2009 at 9:54:59 AM | Objects not showing in "fine" detail level
Ash1012
I'm still fairly new to Revit, so I might be missing something pretty obvious here.
I do electrical design and I am placing duplex and quadruplex receptacles in my plan. If I switch to fine detail level, my quads go away. In medium or coarse, they are there.
This is an issue because we show all of our piping/conduit in double line which needs the fine detail level on to see.
Is there a reason why the quad receptacles would disappear in fine and not the duplex?
Tue, Mar 3, 2009 at 9:59:17 AM | Objects not showing in "fine" detail level
Ash1012
I forgot to add that these are not customized objects. These are from the "out of the box" revit library, so that's not something that might have caused it.
Tue, Mar 3, 2009 at 10:24:52 AM | Objects not showing in "fine" detail level
RevitComponents
RevitComponents Avatar
4 Stars: 22 Votes
YES__
Open the family / edit the family >> select the linework that is not showing up in 'fine detail' >> right-click >> Element Properties... >> Click "Edit" @ Visibility/Graphics Overrides >> Adjust accordingly.
VIOLA Smile
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components]
Tue, Mar 3, 2009 at 10:29:00 AM | Objects not showing in "fine" detail level
The rules for when to use the medium / fine switch has not really been established for most families.  It doesn't make a difference for walls/floors but it can be set in families.  Most family builders treat them the same but it appears that you have found a unique one.  Edit the quad family and I am sure you will find it is switched off in fine visibility.  Edit that.
Tue, Mar 3, 2009 at 10:42:15 AM | Objects not showing in "fine" detail level
Ash1012
Awesome. That was it.
Thanks a bunch.
fine detail missing on duplicated wall, plan view??
Mon, May 1, 2006 at 8:31:20 PM
Any way to show some objects in FINE detail on a coarse detail plan?
Wed, Apr 27, 2011 at 12:36:11 PM
In "Fine Detail" Wall structure is missing...
Tue, Sep 22, 2009 at 1:35:38 PM
wall detail not showing in plan view
Wed, May 22, 2013 at 3:18:27 PM
Moving Detail cuts results in "objects will be deleted" Unacceptable!!
Mon, May 10, 2010 at 3:42:52 PM
Page generation time: 2.3962
