Forums >> Revit Structure >> Technical Support >> TitleBlock default parameters
Tue, Mar 3, 2009 at 9:02:47 AM | TitleBlock default parameters
TeamNga
1 Stars: 1 Votes
Does anybody know how I can change the default parameter value when creating a new title block? For example, the drawn by parameter gives me Author when I create a new sheet with my titleblock. I changed the sample value thinking that was the default value but I still get Author. Where can I change the Author default value to get what I want?
 Thanks everyone.
Tue, Mar 3, 2009 at 9:11:39 AM | TitleBlock default parameters
FJ22
I don't know how your title block is build, at our company we don't use the drawn by parameter. Instead we use the designed by parameter. I don't know why this has been the case but at least it works properly.
Mon, Mar 9, 2009 at 2:06:00 PM | TitleBlock default parameters
TeamNga
1 Stars: 1 Votes
My problem is not that it does not work. I can edit the parameter just fine. What I would like is that when I create my titleblock I can give the drawn by parameter my name so that when I create a new sheet it gives me my name and not Author that I have to edit every time. Just as the checked by gives me checker when I create a new sheet. I would like to have the checkers name by default when I create a new sheet.
Mon, Mar 9, 2009 at 2:42:44 PM | TitleBlock default parameters
I wouldn't complain about entering a few characters but since you do .... just make your drawn by in your titleblock family a type parameter and have types for each author....
Instance Parameters in titleblock not linking
Wed, Dec 28, 2011 at 10:31:23 AM
12
Titleblock Parameters [ 1 2 ]
Thu, Mar 13, 2014 at 4:57:53 PM
17
How to link shared family parameters into an assembly titleblock?
Mon, Apr 20, 2015 at 8:14:15 AM
Mon, Mar 19, 2007 at 11:12:52 AM
Drawn By and Checked By titleblock parameters
Fri, Oct 10, 2008 at 10:43:12 PM
Page generation time: 2.1859
