32 Users Online (30 Members):
Forums >> Revit Building >> Technical Support >> family component color
why when i highlight a family component and click on edit family and go to materials and change the render color it changes fine in the family but loaded back in the project nothing changes either for shaded view or render?
Check the definition of that material in your project under Settings, Materials.
that was it- just needed to use the same material name back in the project.. here is the bigger problem i'm having: when i load the K-series-bar joist-web 30 K 12 component- some of its parts are just lines.. but in the family editor all its parts are solid.. do you know how i can make them all solid in the project?
It may be due to your detail level. The solid geometry might only display when it's set to fine.
wow it was just the detail level in the project.. thanks for getting me over two hurdles tonight..
Changing a color of a modelling component |
Tue, Sep 5, 2006 at 1:15:24 PM
component color |
Thu, Dec 8, 2005 at 5:13:31 PM
Nested Annotation Family in a Detail Component |
Fri, Mar 16, 2012 at 8:56:45 AM
Surface Pattern or Pattern Component Family for Ceiliing Linework |
Sun, May 31, 2015 at 12:33:51 PM
Nested Family - problem with setting origin of loaded component (Revit 9) |
Fri, Aug 22, 2008 at 10:58:05 AM
