Forums >> Revit Systems >> Technical Support >> family component
Tue, Mar 3, 2009 at 2:48:33 AM | family component
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
when i load the K-Series Bar Joist-Angle Web 30k12 into
the project it doesn't have all the metal in it- only some metal
with all the angled metal being only lines.. but when i open it for
editing in the family
editor it shows all the metal angles that make up the joist.. how do i
get it to show all its parts in the project?
Tue, Mar 3, 2009 at 3:37:15 AM | family component
KingRevit
4 Stars: 12 Votes
probably the visibilty settings in the family - select an object that isn't showing up and click on visibility and have a look at its settings
Tue, Mar 3, 2009 at 4:21:54 AM | family component
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
"probably visability settings in the family"
"select an object that isn't showing up" (isn't showing up in the project)
"click on visability" ? you mean visability graphics override from view properties
or vv in the family editor? all four are checked.. and even if i uncheck all four and load back in
the project it doesn't change anything..
if someone could just load the K-series bar joist-angle-web and see how
some of its parts are only lines and those line parts don't render..
Tue, Mar 3, 2009 at 7:28:13 AM | family component
KingRevit
4 Stars: 12 Votes
you should upload your family as mine might be different. then i can have a look
Tue, Mar 3, 2009 at 7:43:10 AM | family component
King - I think this is the stock joist that comes with revit.  Looking at the family, it should show correctly but the poster does not say where it does not show right.  He needs to clarify that.
Wed, Mar 4, 2009 at 5:08:39 AM | family component
KingRevit
4 Stars: 12 Votes
also wwhub i have heard so many time that i haven't changed a family but when i look at it they have the only way to be sure we are all talking about to the same thing is to look at HIS family.
also i use metric so i have different famlies. when you all come out of the stone age and drop imperial the better.
Wed, Mar 4, 2009 at 6:02:29 AM | family component
4 Stars: 205 Votes
"when you all come out of the stone age and drop imperial the better." - LOL, I agree....
Fri, Mar 6, 2009 at 5:25:36 AM | family component
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
i didn't have the detail set to fine in the project
and all of the component was not showing..
thanks everyone..
Nested Annotation Family in a Detail Component
Fri, Mar 16, 2012 at 8:56:45 AM
family component color
Tue, Mar 3, 2009 at 5:14:18 AM
Nested Family - problem with setting origin of loaded component (Revit 9)
Fri, Aug 22, 2008 at 10:58:05 AM
Detail Component in Profile Family - Doesn't Work = Why?
Tue, Dec 22, 2015 at 1:45:50 PM
Model in place component
Wed, Oct 11, 2017 at 11:46:05 AM
Page generation time: 5.3658
