20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Clerestory windows in plan regions
2 Posts No Rating |
I have a bunch of clerestory windows that I've gotten to show up using the plan regions but none of the detailing shows up, they are just blank white boxes in the wall. any suggestions?
You have not given us enough information to help you. You say you see the windows so what's missing?
2 Posts No Rating |
Sorry. the 'rough opening' of the window shows up, however none of the detailing (i.e. window frame, glazing, etc.) shows up. I put one of the walls in question into a blank file for you to look at. One of the windows now has deatailing and two still don't. it is probably a simple stting issue, but I've played with it a good bit and can't get it to work right.
its your visibility settings in your window family
clerestory |
Fri, May 20, 2011 at 8:17:17 AM
Displaying windows above cut plane |
Mon, Oct 27, 2014 at 2:39:24 AM
Plan Region nesting problem |
Mon, May 18, 2015 at 6:04:23 PM
Plan Region Layout |
Fri, Jan 25, 2008 at 7:16:06 PM
Clerestory Walls |
Wed, May 17, 2006 at 1:54:51 PM
