Forums >> Revit Building >> Technical Support >> Invisible lines in Titleblock - Is there a defpoints?
Tue, Jun 21, 2005 at 7:34:15 PM | Invisible lines in Titleblock - Is there a defpoints?
Birdman
Our standard titleblock does not print with a border but I have used invisible lines in the titleblock to show the extent of the page. The only problem is this does not display in the model unless you hover the mouse over it which does not help when you are inserting views. Is there a way to draw lines that I can see but do not print as we can with defpoints?
Tue, Jun 21, 2005 at 10:55:46 PM | RE: Invisible lines in Titleblock - Is there a defpoints?
eldados
eldados Avatar
4.5 Stars: 8 Votes
not that I'm aware off... the way around it is to have short lines in the corners of your sheet.
titleblock & printing
Thu, Jun 18, 2015 at 8:45:49 PM
Invisible Dimension Lines
Thu, Dec 29, 2011 at 6:04:48 PM
Invisible lines removed from Line Styels
Mon, Feb 21, 2011 at 12:10:18 PM
turning off or on lines in a titleblock
Tue, Sep 30, 2014 at 10:29:43 PM
Invisible Lines Can't Find Them
Thu, May 14, 2009 at 8:38:06 AM
Page generation time: 0.2764
