Forums >> General Discussion >> Revit Project Management >> CAD Utility lines in Revit
Mon, Mar 2, 2009 at 7:02:27 PM | CAD Utility lines in Revit
jgmas
I received the survey (dwg file) from our consultant, when i import it into revit all the utility lines do not show correctly (it just shows a solid line for each utility).
 Is there a way to fix that? Does revit recognize autocad line types?
 Thanks
Tue, Mar 3, 2009 at 7:19:49 AM | CAD Utility lines in Revit
You should be using your HELP for some of this.  Linetypes are fully explained there.  In addition, you can search the forums for discussions on linetpes with imbedded letters. Also look here http://revitbeginners.blogspot.com/2006/09/utility-lines-workaround.html
Tue, Mar 3, 2009 at 4:49:22 PM | CAD Utility lines in Revit
jarosa
jarosa Avatar
4 Stars: 5 Votes
jgmas,
I just uploaded this "line" family a few days ago. Please try it and let me know how it works for you.
http://revitcity.com/downloads.php?action=view&object_id=6725
John
Utility lines
Sun, Aug 7, 2005 at 10:20:16 PM
portable license utility
Tue, Jan 24, 2006 at 4:36:42 PM
Revit MEP 2012 - Linked Cad Lines being trimmed by Revit Plumbing Fixtures
Mon, Nov 7, 2011 at 12:54:25 PM
Utility lines on site plans
Fri, Sep 15, 2006 at 1:01:29 PM
Use 'License Tranfer Utility' for Temporary, Telecommuting Revit Drafters?
Wed, May 12, 2010 at 3:46:54 PM
Page generation time: 6.9497
