Forums >> Revit Building >> Technical Support >> Linked Revit file
Mon, Mar 2, 2009 at 4:17:05 PM | Linked Revit file
diesellam
I'm curious if there's a way you can freeze certain elements in the linked revit file?  (Similar to freezing a layer in the Xref in AutoCAD.)
Thanks in advance.
Mon, Mar 2, 2009 at 4:33:31 PM | Linked Revit file
wheelergc
You can edit the visibleity options of linked revit files.  You can not do anything to Imported AutoCad files.  Go to the links under the Graphics override adn change to a custom setting then you can change what you want to see in the linked file
Mon, Mar 2, 2009 at 4:46:37 PM | Linked Revit file
diesellam
It works, thanks.  But I guess my next question is:
Let's say there are 3 floor slabs are in the linked Revit file.  I just want to have one of the floors frozen, but the other 2 visible.  Is there a way to do that?  Seems like the Visibility/Graphics override only applies everything of that particular element, but not within the element.
Thanks in advance.
Mon, Mar 2, 2009 at 6:11:10 PM | wheelergc
cercas
5 Stars: 3 Votes
Quoting wheelergc from 2009-03-02 16:33:31
Sorry, but this is not truth, you can manage visibily settings of imported autocad files, in the imported objects, imports in families, you should find the file layers...
Joao Cercas
On Revit 2010 (SP3)
Linked Revit Topography file displayed in hidden lines in 3d view main bld file
Sat, Jul 7, 2012 at 3:38:16 PM
Scheduling from linked Revit file
Tue, Mar 27, 2012 at 7:39:28 AM
edit linked file in place or at least open linked file withou having to unload
Fri, Dec 4, 2009 at 9:57:47 AM
Linked File, how can I dimension it?
Sun, Dec 19, 2010 at 8:08:50 PM
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
Page generation time: 2.7438
