Forums >> Revit Building >> Technical Support >> Handle extrusion shows through panel
Mon, Mar 2, 2009 at 9:30:08 AM | Handle extrusion shows through panel
jarosa
jarosa Avatar
4 Stars: 5 Votes
For the life of me I can't seem to find out how to make the exterior door handle extrusion not to show through panel. The handle is a nested family in the door family. The only way it goes away is if I delete it.
John
Mon, Mar 2, 2009 at 10:07:37 AM | Handle extrusion shows through panel
KingRevit
4 Stars: 12 Votes
once you load it into a project it will show as you intended
Mon, Mar 2, 2009 at 10:09:34 AM | Handle extrusion shows through panel
Assuming this is a face based family (handle) is it mounted on the wrong face?
Mon, Mar 2, 2009 at 10:17:00 AM | Handle extrusion shows through panel
jarosa
jarosa Avatar
4 Stars: 5 Votes
KingRevit, That is a screenshot of it in the project. It shows fine in the family editor.
WWHUB, It's a generic model family. Placed on the correct side. I even moved it 1/8" away from panel and it still shows through to the other side.
John
Mon, Mar 2, 2009 at 11:32:27 AM | Handle extrusion shows through panel
If you edit the handle family, is there an invisible line in it?  If so, delete it.
I still think this is a placement issue.  Perhaps the handle family is not locked to the door but is located based on the wall.  You might try t-inserting this and locating it relative to the door plane.
Mon, Mar 2, 2009 at 4:58:47 PM | Handle extrusion shows through panel
jarosa
jarosa Avatar
4 Stars: 5 Votes
WWHUB,
You're on the right track. I've been messing with this family for so long in the same wall thickness and that the family itself is not constrained correctly. The family is in a 6" wall and the project wall is a 8" wall. Looks like I have to go back to the beginning and reconstruct this door family. Family editor wins today's match.
Thanks,
John
Door handle
Thu, May 19, 2011 at 6:19:45 AM
Cutting a Curtain Panel
Wed, May 14, 2008 at 8:19:29 AM
Fillet arc not working on baluster panel extrusion
Wed, Oct 26, 2011 at 5:56:34 AM
re-joining (?) cut extrusion with extrusion
Tue, Apr 17, 2007 at 10:26:27 PM
Shape handle
Thu, Feb 19, 2009 at 6:32:48 AM
Page generation time: 0.2604
