Forums >> Revit Building >> Technical Support >> Ground Plane / Background image
Tue, Jun 21, 2005 at 4:23:51 PM | Ground Plane / Background image
jweber
New to Revit and need help. I am trying to render a scene. I have my model ready and I want to put in a ground plane and a background image. I know the steps to get these images into the scene but when I render the image for the ground plane is the entire background and I have no "sky". What am I doing wrong?
Tue, Jun 21, 2005 at 6:20:03 PM | RE: Ground Plane / Background image
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In your rendering settins for that view. Make sure backgroud is ticked and you have the appropriate image loaded. Also check to see that the ground plane is at the correct level in relation to the model in these settings. HTH.
Ground Plane
Mon, Feb 21, 2005 at 5:05:02 PM
Rendering - Changing Ht of Ground plane does not 'stick'
Thu, Mar 10, 2005 at 4:35:08 PM
Gray Ground Plane in My renderings
Fri, May 29, 2009 at 5:38:03 PM
Lost gradient image in background (sky, horizon, ground)
Wed, Jun 12, 2013 at 3:34:07 PM
REA 2009 Background Image when rendering
Mon, Nov 17, 2008 at 8:50:49 AM
Page generation time: 0.3988
