Forums >> Community >> Newbies >> Taking an existing object and tweaking it
Sat, Feb 28, 2009 at 6:47:43 AM | Taking an existing object and tweaking it
SemiDeatched
I think I am missing something really simple here...
 If I add a boring single door to my model but later find that it would be nice if I could modify the door on a one-off basis how would I achieve that?
 For example... I place a standard door in a wall.  The door comes from a standard family.  But later I decide that I want to change this door to have say a glazed panel in the middle.  I would obviously like the panel to be part of the door.
How do I take this existing door and create an in-place family of my own door variant?
Thanks in advance
SD
Sat, Feb 28, 2009 at 6:58:13 AM | Taking an existing object and tweaking it
4 Stars: 205 Votes
My advise? Open that door, save with other name to preserve that family then create the panel in glass like you want, now you have two families, one without the glass panel and other with glass panel, when you need just load the door you want...
Sat, Feb 28, 2009 at 7:23:11 AM | Taking an existing object and tweaking it
SemiDeatched
Thanks
Revit existing phase problem in 3ds Max
Tue, Jul 22, 2014 at 4:11:11 PM
Walls set as existing not showing up in existing phase settings.
Sat, Aug 4, 2012 at 11:21:58 AM
Existing Wall Rendered
Sun, Jul 27, 2008 at 5:23:30 PM
Block existing model. [ 1 2 ]
Tue, May 24, 2016 at 2:11:05 PM
16
Embedded Detail Component and Object Styles
Fri, Feb 12, 2010 at 3:21:25 PM
Page generation time: 0.2108
