Forums >> Revit Structure >> Technical Support >> CHANGING DEFAULT TEXT
Fri, Feb 27, 2009 at 3:47:59 PM | CHANGING DEFAULT TEXT
vanderloo
I keep chcanging my text size in the settings menu to 1/8" and it keeps changing back to 3/32". Is there some other place that supercedes this setting? I want the text tool to default to 1/8".
Thanks
Sat, Feb 28, 2009 at 9:53:51 AM | CHANGING DEFAULT TEXT
Revit defaults to the last test type that you used.  If you used 1/8" then after placing you changed that to 3/32" Revit still has you last using 1/8".  When you start your text, change the type in your options window first.
Any way of changing default view of a family thumbnail?
Thu, Nov 7, 2013 at 8:07:04 AM
CHANGING SIZE OF DIMENSION TEXT BOX
Wed, Feb 25, 2009 at 4:22:17 AM
Default Text Style
Thu, Mar 6, 2008 at 11:26:53 AM
Changing Text Size in a text box
Thu, Aug 6, 2009 at 6:41:13 AM
How to change the default text font and size
Mon, May 3, 2010 at 1:17:39 PM
Page generation time: 0.3881
