12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> changing dimension precision?
Trying to round off dimensions to the inch on site plan. Right now it's rounding at /32". How do I change this?Thanks
1 Posts No Rating |
Question about dimensions. Is it possible to "stack" fractions in a demension as we could in AutoCad?
hey guys, type UN and enter and its going to open a project units window, there you can do what you are asking here. TRY IT
62 Posts No Rating |
settings/annontations/dimensions then once you are in the menu under units format at the bottom you can change the rounding. I do not know if you can stack the fractions though
11 Posts No Rating |
So, I just did this on my project and I set the precision to 1/4". However, my dims are still showing at 1/8 and 1/16, even 1/32. What's going on? I am using the Aaligned Dims on Detail Lines. Is that a reason it's having issues?
You can have multiple dimension types in a project. So did you do that? If so, change the dimension type for those dimensions.
Setting precision for exporting to cad |
Mon, Mar 12, 2012 at 10:43:34 AM
Dimension Visability in Dependant View |
Wed, May 28, 2008 at 11:50:35 AM
revit precision in schedules |
Wed, Dec 5, 2018 at 8:28:39 AM
Changing Dimension object in Array |
Thu, Jul 27, 2017 at 6:05:05 AM
CHANGING SIZE OF DIMENSION TEXT BOX |
Wed, Feb 25, 2009 at 4:22:17 AM
