Forums >> Revit Building >> Technical Support >> aia architectural standard
Mon, Jun 20, 2005 at 2:22:58 PM | aia architectural standard
parleyburnett
3 Stars: 2 Votes
Could someone tell me what the aia standard is for numbering details on a sheet? Is it as if you're reading a book.... top left to right, or bottom right to left... Thanks
Mon, Jun 20, 2005 at 6:44:12 PM | RE: aia architectural standard
TomDorner
4.5 Stars: 25 Votes
I don't believe there is any AIA standard other than layer standards and they are part of the larger National CAD Standard. We have not paid our $450 for a copy of the CAD standard as it is not that important to our firm. You can preview it an learn a lot about it at: http://www.nationalcadstandard.org/NCSpres2.pdf HTH Tom
Mon, Apr 6, 2009 at 4:20:46 PM | aia architectural standard
phantomload
It is my understanding the number is top right to bottom left on all sheets.  Therefore if you had a half sheet of drawings they should be justified away from the spine where they are easily accessable.  If additional details are added in CCD/Addenda the drawings are simply the next number on the sheet, and follow the same layout (progressing towards the spine).
Current Poll "Do you have your AIA?"
Wed, Dec 10, 2008 at 12:36:22 PM
.PCP Files and AIA standard
Wed, Jan 10, 2007 at 5:04:32 PM
LIMIT OF CONTRACT
Fri, May 12, 2006 at 8:04:41 AM
AIA Best Practices - Organizing Construction Documents
Thu, Mar 20, 2014 at 2:36:36 PM
Exporting Revit to AutoCAD New Problem - no reason...
Mon, Feb 11, 2008 at 6:11:27 PM
Page generation time: 0.5838
