Forums >> Revit Structure >> Technical Support >> topo survey AutoCAD to Revit
Thu, Feb 26, 2009 at 10:38:07 AM | topo survey AutoCAD to Revit
Allan1983a
I have a 2d AutoCAD topo survey drawing that I wish to turn into a 3d Revit Topograph survey.  What is the esiest and quickest way of doing this, I know revit could select it by imported layers but as its 2d this doesnt work! any help would be app ASAP as I need to show the bosses how it can be used!
Cheers
Allan
Thu, Feb 26, 2009 at 10:42:11 AM | topo survey AutoCAD to Revit
4 Stars: 205 Votes
Do you have the "Contour Lines" in 3D??? Points in 3D???
Thu, Feb 26, 2009 at 10:57:40 AM | topo survey AutoCAD to Revit
Allan1983a
no its all in 2d....... completely flat!!!! lol
Thu, Feb 26, 2009 at 11:24:32 AM | topo survey AutoCAD to Revit
4 Stars: 205 Votes
"no its all in 2d....... completely flat!!!! lol" - Lol, and now??? are you waiting for a miracle????
Thu, Feb 26, 2009 at 11:45:41 AM | topo survey AutoCAD to Revit
Manny
3.5 Stars: 6 Votes
if you open your 2d in Auto CAD change the elevation for all the countor lines then re-insert.
Once in revit, go to "TOPOSURFACE" TO CREAT IT, INSTEAD OF USING "POINT" USE THE "USE IMPORTED"
THEN "IMPORT INSTANCE" THEN SELECT YOUR CAD FILE THEN A "ADD POINTS FROM SELECTED LAYERS" WINDOW WILL OPEN THERE SELECT THE AUTO CAD LAYERS YOU WANT TO USE FOR YOUR TOPO THAT SHOULD DO THE WORK, BUT DON'T FORGET TO "CHANGE THE Z VALUE IN AUTO CAD FOR IT TO WORK"
SEE ATTACH IMAGE
autoCAD Survey Plans to 3D Topo
Fri, Aug 1, 2008 at 4:12:58 AM
Topo Surface from autocad into revit
Tue, Oct 13, 2009 at 10:37:25 PM
importing topos for a Site Plan
Sat, May 28, 2005 at 10:20:13 PM
Change of Infornation on a Call out Ref and Easting/Northings on a Topo survey
Thu, Feb 21, 2013 at 12:37:10 PM
Importing AutoCAD topo 3D lines
Wed, May 25, 2005 at 3:33:44 AM
Page generation time: 1.6946
