Forums >> Revit Building >> Technical Support >> Hide/isolate in view versus in print
Wed, Feb 25, 2009 at 5:36:56 PM | Hide/isolate in view versus in print
rhabian
I'm using REVIT 8, and I need to know how to hide/isolate an item(s) in a view and have that invisibility remain during printing. I understand that version 2008 might have a right-click command of "hide in view", but nothing like that in Version 8?
I went through my project and used the sunglasses to hide objects and categories in different views, but when I went to print the project, i was hosed. My bad, for sure, but how do I make the temporarily hidden objects remain hidden when I print?
Help?
Thanks.
Thu, Feb 26, 2009 at 4:12:34 AM | Hide/isolate in view versus in print
tim123
4 Stars: 19 Votes
I think that in Revit 8 you can only hide the category and not individual elements - we're almost up to Revit 2010 (4 versions later) so you're losing out on a lot of the features that Revit now offers.
Sat, Mar 21, 2009 at 9:38:29 PM | Hide/isolate in view versus in print
fixybopixy
i am having this exact problem right now in Revit 2009. Basically, in the section view, I have a whole bunch of things hidden (i.e., people and cars) But when i put the section view on a sheet layout, and i print that sheet layout, those hidden things appear!
 in addition, I edited the level lines in teh section view but when i print it, it goes back to the old  way the level lines were. im attaching 2 images for u guys to see the problem, one has the section as it appears on my screen, which is how i want it to print and the other is how it actually prints (prints incorrectly)
 thanks!
rebecca
Sun, Mar 22, 2009 at 7:39:19 AM | Hide/isolate in view versus in print
4 Stars: 205 Votes
Those object in the back of the image are "Masses"??? If so, did you try in VG uncheck the visibility???
Sun, Mar 22, 2009 at 1:17:08 PM | Hide/isolate in view versus in print
fixybopixy
what is "VG"? no, they r not masses that i created in revit. they r buildings I imported from rhino (our class site model is in rhino). i wanted to create masses but was having problems getting them to appear. do u know how to do that?
Sun, Mar 22, 2009 at 2:07:22 PM | Hide/isolate in view versus in print
4 Stars: 205 Votes
VG= Visibility/Graphic, so if those objects are from Rhino so in VG/Imported Categories turn off those "Layers"...
About the mass, export the mass in SAT File (ACIS Solid) not in MESH, then when you import to Revit you can apply Walls, roof, Floor by face and surtains systems in that ACIS solids...
Sun, Mar 22, 2009 at 3:53:37 PM | Hide/isolate in view versus in print
fixybopixy
thakns for the quick reply. actually i exported from rhino to 3dsmax (since i dont know rhino), and then from 3dsmax to Revit. given that it is actually coming from 3dsmax, do u know how i can get rid of those jagged blue lines on the imported bldgs? if i can do that i wont have to make new masses in revit.
 drawing is attachced
Sun, Mar 22, 2009 at 4:01:20 PM | Hide/isolate in view versus in print
fixybopixy
but i like the idea of what u r suggesting to me, because some of the buildings are kind of compilicated (i.e. the one of the fancy historic church, st. vibianas, in upper right) and it would be smarter to simply import the bldgs from rhino and then add walls or floors so taht we dont see the jagged blue lines which r ugly and annoying
Hide Isolate
Fri, May 2, 2014 at 2:34:08 PM
hide ellements when you want to print,BIM gets in the way
Thu, Aug 28, 2008 at 10:51:05 AM
Temporary Hide Isolate
Mon, Mar 3, 2008 at 12:09:10 PM
Isolate one wall
Wed, Jan 25, 2006 at 9:19:32 AM
Hide/ Isolate objects question
Tue, Mar 18, 2008 at 6:35:09 AM
Page generation time: 4.7559
