18 Users Online (16 Members):
Forums >> Revit Structure >> Technical Support >> Cutback on truss member ends
Is there a way to "cope" the ends of memebers of a truss, especially the web members, so that they fit nicely together without having them appearing to be separated? See pic. Thanks
If that is a wood truss I would use a gusset. It is the way they build them. Is this a family you built or a down load?
----------------------------------- BallewDesigns.com |
It is just one of the standard truss families. It will be a steel tube truss, with welded connections. I would like to have the ends of the diagonal webs angled to fit into the corner made by the vertical webs.
hey did you find a solution for this ?
Tab to cycle through and select individual chord, or web member. Unpin and pull the grip.
Hi
hope this will give u an idea
1.modify web family (structural beam family)
2. use COPE   or cut opening by face to clean the join)
see attached images. ty
Edited on: Thu, Aug 28, 2014 at 2:27:54 AM
Dude, so much thanks for this!!!!!
custom truss cut backs |
Sun, Sep 22, 2013 at 1:15:01 AM
connections in the structural truss |
Thu, Apr 4, 2013 at 10:38:14 AM
creating box section truss system |
Tue, May 10, 2011 at 5:41:28 PM
Revit 2018 - Placing Structural member (King Truss) on sloped plane |
Wed, Feb 27, 2019 at 7:24:39 AM
Steel truss family - need multiple diagonal sizes and depth based on out to out |
Wed, Mar 2, 2016 at 12:06:26 PM
