Forums >> Revit Building >> Technical Support >> Dimensioning Drafting Views
Wed, Feb 25, 2009 at 1:52:56 PM | Dimensioning Drafting Views
c3desn
4.5 Stars: 3 Votes
I still use Autocad on some sections, etc. My problem is when I reload I lose the dimensions even though that dimensioned object might not have changed (the .dwg changed on another part). I dimension and annotate using Revit.
Wed, Feb 25, 2009 at 1:56:59 PM | Dimensioning Drafting Views
Link instead of inserting the cad drawing.
Thu, Feb 26, 2009 at 6:47:36 AM | Dimensioning Drafting Views
c3desn
4.5 Stars: 3 Votes
Tried that, no luck. It does this 99 % of the time...Occasionally, the dimensions will stay. Can't figure out the patten.
Thu, Feb 26, 2009 at 4:10:43 PM | Dimensioning Drafting Views
coreed
coreed Avatar
4 Stars: 16 Votes
try creating a workset just for the section link and import the section link into the workset. that should solve your problem of losing dimemsions when reloading.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Apr 3, 2009 at 8:36:24 AM | Dimensioning Drafting Views
mehsabsa
coreed.. i tried to do what you suggested but i am still having problem..i link the cad drawing to drafting view with craeting a different workset.. but whenever i reload same cad file, some of my dimension erased eventough any changed made related objects.. i dont know why some stay some erased.. any suggestion??
Fri, Apr 3, 2009 at 8:48:41 AM | Dimensioning Drafting Views
c3desn
4.5 Stars: 3 Votes
As a quick solution. I drew thin lines where I wanted to locate dims..then dimensioned to them so the dim was associated to the line not the imported dwg. If I had to reload I could then just move the lin(s) as needed. Wasn't so bad. One thing, if you've already dimensioned and added to the dim. text string (ie: Head Ht. = blah blah) and then you re-associate to the lines after the fact you will lose this info and have just the dim text only so put the lines in at the beginning.
Fri, Apr 3, 2009 at 9:03:24 AM | Dimensioning Drafting Views
mehsabsa
it is a solution but wondering if there is easy way to do it with out drawing reference lines for dimension.. I am sure there must be a diffrerent and easy way. i posted these questin at chatting linh, but could not get a proper answers..
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
Converting Model Views to Drafting Views
Fri, May 13, 2016 at 2:13:29 PM
Save a sheet of drafting views
Wed, Mar 1, 2017 at 5:34:28 PM
DRAFTING VIEWS ON MORE THAN ONE SHEET (REVIT 2012)
Wed, May 23, 2012 at 8:42:46 AM
DRAFTING VIEWS
Fri, Oct 13, 2006 at 3:34:29 PM
Page generation time: 1.1549
