16 Users Online (15 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Revit 2009 MEP Newbie - Can place anything on walls not created by Autodesk
Wed, Feb 25, 2009 at 1:41:56 PM | Revit 2009 MEP Newbie - Can place anything on walls not created by Autodesk
heinzk1
I am a Newbie to Revit MEP 2009 and hating every minute of it.  That said, I have linked in an Architects Revit plan into my new project.  When I try to place a piece of equipment like a sink or thermostat on a wall it wont let me do it.  If the wall was drawn on the actual sheet it has no probelms.  What am I doing wrong?
 KHeinz
Wed, Feb 25, 2009 at 1:58:51 PM | Revit 2009 MEP Newbie - Can place anything on walls not created by Autodesk
If your elements are hosted, then the host (or a copy of it) has to reside in your model.  Copy monitot the wall and your items will then work.
Wed, Feb 25, 2009 at 4:56:18 PM | Revit 2009 MEP Newbie - Can place anything on walls not created by Autodesk
corymac82
Clarification:
You can host to the face of a linked .rvt file, but not to the actual family within the linked file, ie. walls, ceilings, etc.  Change your fixture to be a face based family or, as mentioned previously, copy/monitor the elements you need to use as hosts.
Revit MEP 2008 Newbie!
Mon, Oct 1, 2007 at 10:00:09 AM
What Revit version to use when creating families for SEEK?
Thu, Apr 17, 2014 at 9:37:02 AM
Revit Structure to MEP
Tue, Feb 24, 2009 at 7:19:48 AM
AutoDesk Buidling Systems - MEP
Thu, Sep 21, 2006 at 4:28:54 PM
Revit MEP or AutoCad MEP
Fri, Oct 14, 2011 at 8:21:49 AM
Page generation time: 3.8220
