Forums >> General Discussion >> Wishlist >> ADA Ramp
Mon, Jun 20, 2005 at 2:04:01 PM | ADA Ramp
VF1Stampede
3 Stars: 2 Votes
I need an accessible ramp compnent to get people up from grade over a curb. Has anyone built one or know how I might construct one using the ramp command?
Mon, Jun 20, 2005 at 6:21:23 PM | RE: ADA Ramp
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just use the ramp tool. If its a straight forward rectangle use the run command otherwise sketch it out and set the appropriate settings in your ramp properties. Please note; ramps do not display correctly in plan. I typically use a filled region to represent the ramp in plan and conceal anything below it. HTH.
Trying to make a non ADA ramp but always have problems with railings, need help!
Wed, Oct 16, 2013 at 9:10:43 AM
3D ADA Ramp
Thu, May 1, 2008 at 9:45:11 AM
Railing at ramp and stair
Fri, May 29, 2009 at 7:40:59 AM
Ada Componets
Thu, May 7, 2009 at 10:49:03 AM
A ramp!
Thu, Jan 21, 2016 at 11:37:45 AM
Page generation time: 0.2533
