11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Ceiling color problems
26 Posts No Rating |
(Rev Arch 2009) I cant seem to change the color (perspective shaded view) of the ceiling. (using revit default 2X2 susp)... Nothing affects it. It remains grey no matter the material properties...any ideas?
23 Posts No Rating |
It works fine on my end. Make sure you choose the color you want in the material properties dialogue. There is a check mark box that asks, "Use Render Appearance for Shading?" Make sure you leave that box unchecked, click on the color selector box, and choose the color you want. That should do the trick.
since i restarted the program, it seems to be working correctly. just a hiccup i guess.
walls and ceiling are same color |
Sat, Jan 12, 2008 at 7:08:45 AM
Barrel Vault ceiling problems |
Mon, Nov 22, 2010 at 4:58:04 PM
Color Scheme in Reflected Ceiling Plans? |
Thu, Nov 20, 2014 at 10:16:01 AM
Revit 2016 How to set the wall height to respond to ceiling heights? |
Sun, Apr 24, 2016 at 6:09:20 PM
Ceiling edit boundary problems |
Wed, Apr 18, 2012 at 12:59:37 PM
