Forums >> Revit Building >> Technical Support >> Structural Columns moving on their own
Mon, Jun 20, 2005 at 1:33:13 PM | Structural Columns moving on their own
Paulie
I'm working in a file where steel and concrete structural columns have been placed on the column grids. Once placed they were aligned and locked to the appropriate grids. Upon exiting and reopening the file it's been noticed that some of the columns have moved somewhat. Usually it's just a matter of inches. I've also noticed that when selecting structural columns for editing that a blue circle appears once the column is highlighted and this circle can be moved independently of the column it's associated with. Question #1 - Does anyone know what would cause the columns to move and how to prevent the movement from happening? Question #2 - What is the purpose of the blue circle?
Tue, Jun 21, 2005 at 11:10:20 PM | RE: Structural Columns moving on their own
eldados
eldados Avatar
4.5 Stars: 8 Votes
Looks like a bug in Revit AFAIK, if you move walls that are attached to the grid, the columns will move as well... as to the second Q, what blue circle? I could not see it Smile
structural wall VS structural columns
Tue, Apr 26, 2016 at 3:49:39 PM
Structural columns
Mon, Jan 16, 2012 at 8:37:32 AM
Structural Columns not cutting walls
Mon, Jan 4, 2016 at 4:13:25 PM
Beams won't intersect or close-up to Structural Columns. Solution ?
Tue, Oct 18, 2016 at 2:01:11 PM
Structural graphical columns schedules
Mon, Apr 25, 2016 at 3:19:18 PM
Page generation time: 5.8955
