Forums >> Revit Building >> Technical Support >> See walls behind in 3d view
Wed, Feb 25, 2009 at 7:39:31 AM | See walls behind in 3d view
bbigelow
I am working on a house and when I go to the 3d view and when I click on the hidden view all the lines beyond the surface of the exterior walls show up.  Need Help to remove lines beyond and Im using Revit 2009.
Thanks
Wed, Feb 25, 2009 at 8:32:33 AM | See walls behind in 3d view
4 Stars: 205 Votes
Can you put here some images to see the problem??? If it's what i think it just delete that 3d View and create a new one but i need to check....
Wed, Feb 25, 2009 at 8:33:59 AM | See walls behind in 3d view
bbigelow
Thanks for the input...I deleted the 3d view and started a new one and everything looks great.  I cant believe I wasted time trying to figure out this porblem.
Wed, Feb 25, 2009 at 8:41:03 AM | See walls behind in 3d view
4 Stars: 205 Votes
Yeah, can you please tell me what "graphic card" do you have?????
Wed, Feb 25, 2009 at 8:45:32 AM | See walls behind in 3d view
broncos4life
3.5 Stars: 11 Votes
I am not sure if I understand your issue, but if its what I think it is, next time it happens just hit the "Home" button near the View Cube in 3D and this should fix the problem.  This would be alot quicker than deleting and making a new view.
Edited on: Wed, Feb 25, 2009 at 8:46:18 AM
how to make walls opaque in a camera view
Fri, Jan 4, 2013 at 11:22:18 AM
3D View gone crazy - walls and floors etc missing from view?
Wed, Feb 25, 2015 at 12:09:49 PM
Walls do not show up in plan view
Tue, Mar 10, 2009 at 1:49:55 PM
Roof hides walls in plan view
Mon, Apr 20, 2015 at 7:48:45 AM
Can't see first storey walls in first storey plan view
Mon, May 5, 2014 at 9:02:22 PM
Page generation time: 0.8244
