Forums >> Revit Structure >> Technical Support >> not sure.....
Wed, Feb 25, 2009 at 1:55:08 AM | not sure.....
Allan1983a
I have no idea how to put into words this problem, basically i am trying to put a sloped curved beam in between two defined points, and cannot think how to do it, ive attached a jpeg of the 3d to show the points i wish to connect! any help would be greatly received!
Wed, Feb 25, 2009 at 3:41:14 AM | not sure.....
tim123
4 Stars: 19 Votes
The attached image shows an in place structural component created with a curved sweep and a loaded profile.  Is this what you are trying to achieve?
Wed, Feb 25, 2009 at 4:14:49 AM | not sure.....
Allan1983a
yes that does seem to be what im after! i can create the curve easy enough but then making it a sloped curve i cant figure!
 Is this a file i can downlaod?
Wed, Feb 25, 2009 at 4:57:02 AM | not sure.....
tim123
4 Stars: 19 Votes
After I created the curved beam I unlocked it (edit the family and click on the beam - it has a padlock on that prevents it from rotating).  It can then be rotated.
Thu, Feb 26, 2009 at 4:32:32 AM | not sure.....
FJ22
I think what you're trying to create isn't easy to make.
It's easy to create a curved beam, and it's easy to make a beam which has a higher endpoint then the starting point.
But altogether it's very hard to make, because the beam will be torn. And i guess that's not what you want.
Thu, Feb 26, 2009 at 4:46:55 AM | not sure.....
Allan1983a
no..... i have managed to do it but it still doesnt look right as it wants to twist.  I created a sloping ref plane between the 2 points i wanted then on plan drw the curved beam to that ref plane, thus creating the curved slope i wanted but it has a twist on the steell....
Thu, Feb 26, 2009 at 4:49:18 AM | not sure.....
FJ22
Yep, that's what I thought already. Unfortunately there's no commando to keep the beam parallel to the level, or maybe there is but I haven't found it yet...
Thu, Feb 26, 2009 at 5:49:29 AM | not sure.....
tim123
4 Stars: 19 Votes
The beam would indeed be twisted.  To create the beam in real life it would have to be twisted.  You can create the twist in the beam to correct this by using the swept blend tool using the same profile rotated to the relevant angle at each end.
Page generation time: 0.0095
