Forums >> Revit Building >> Technical Support >> my extrusions are transparent?
Tue, Feb 24, 2009 at 4:01:16 PM | my extrusions are transparent?
vanderloo
Since I'm having such difficulty with wall openings, I created an extrusion to represent a front entry wall with an arched opening and 2 soffit walls returning from this arched extrusion to the front wall of the house.(see screenshot attachment) 3 questions;1. how do I make these extrusions appear in shaded 3d view as walls, (they are now transparent)2. I would rather have created walls with these size and shaped openings but I wracked my brain trying to figure out how and was unable. Anyone know of any tutorials or resources that may help?3. Why am I unable to join geometry of these 3 elements.Thank You
Tue, Feb 24, 2009 at 5:29:12 PM | my extrusions are transparent?
qthdad
5 Stars: 2 Votes
For the transparency issue. First, check your extrusion Materials properties. Second, when creating the extrusion, pick Walls as the category. From your image, it appears that you have extruded a Mass. You can verify this by hovering the cursor over the object and looking at the bottom left to see what type of object Revit reports.
For the joining, if they are extruded walls, they should join. Some extruded families, I've noticed, cannot be joined, such as casework.
Tue, Feb 24, 2009 at 5:44:57 PM | my extrusions are transparent?
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
You can use that mass to create walls "by Face"; in the massing section of the design bar on the left, there are options to create walls, roofs, floors and such by face.  you can then hide the massing object all-together and only the walls will appear.
Tue, Feb 24, 2009 at 5:56:54 PM | my extrusions are transparent?
vanderloo
Good stuff! Thanks all.
Phil
Joining extrusions
Tue, Jul 26, 2022 at 3:58:08 PM
Transparent object
Tue, Sep 14, 2010 at 1:18:34 PM
naming extrusions
Thu, Oct 10, 2013 at 10:00:24 AM
Creating transparent material such as 3FORM
Wed, Aug 26, 2009 at 8:09:06 AM
Rotate in 3d
Tue, Jan 15, 2019 at 1:20:21 PM
Page generation time: 1.1443
