Forums >> Revit Building >> Technical Support >> How do you create a column that the proportions adjust to the height
Tue, Feb 24, 2009 at 9:22:17 AM | How do you create a column that the proportions adjust to the height
sippel26
I'm trying to create a Doric Column based on the classical portions of the order.  Essentially I want to be able to give it a height and all on the components of the column (i.e. the base, the entasis, the astrigal, the torus, abacus....) maintain the correction proportions in relation to the height.  As is the case in the classical orders every comonent of the column is based on the lower diameter of the column.  For example the height of the plinth is 1/6 the diameter of the column. I'm guessing that I need to come up with a formula in the parameters based on the diameter of the column????  Any help would be appreciated.
Tue, Feb 24, 2009 at 1:35:32 PM | How do you create a column that the proportions adjust to the height
LIZARD2806
3.5 Stars: 7 Votes
That will be one heck of a family, but it is doable.  Start with the "Column Diameter-Bottom".  Then make a parameter called "Plinth Height" and use the formula  "Column Diameter-Bottom/6"
You'll need to do that for every dimension you want changed.  Don;t forget to post that one when you are done! Smile
HTH
Tue, Feb 24, 2009 at 4:39:20 PM | How do you create a column that the proportions adjust to the height
mrmoo
mrmoo Avatar
2 Stars: 1 Votes
That sounds like an amazing idea.  i've contemplated making such an item but the logistics involved are way over my head at the moment. good luck!
Revit 2010 - It's a good thing... Stop Fighting it.
Wed, Feb 25, 2009 at 8:54:53 AM | How do you create a column that the proportions adjust to the height
sippel26
I started playing with it a bit and that's essentially what I've come up with.  I have a few issues still left to work out but I will upload it when I'm done.
Make Girder adjust with column Height
Thu, Oct 20, 2011 at 3:03:35 PM
Column Confusion
Sat, Mar 21, 2009 at 4:41:06 PM
Craftsman Column Problems
Wed, Jun 25, 2014 at 2:16:06 PM
Attaching Columns
Thu, Apr 7, 2005 at 11:22:36 PM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
Page generation time: 1.5571
