Forums >> Revit Building >> Technical Support >> Masking Region Draw Order
Tue, Feb 24, 2009 at 8:12:17 AM | Masking Region Draw Order
CraigEngland
Is there a way I can set a masking region to hide some items but not everything it goes over?
I have a drawing with a referenced site plan. I want to keep most of the site plan, but remove the building and keep the new lines I have drawn over it. Is there some way to do this?
Tue, Feb 24, 2009 at 8:59:46 AM | Masking Region Draw Order
broncos4life
3.5 Stars: 11 Votes
After making your masking region you can select it and then on the options bar is the draw order and you can use that.  I dont think theres any other way to do it.
A side thought...anyone else wish you could change the drawing order of multiple items at a time?
Tue, Feb 24, 2009 at 10:33:17 AM | Masking Region Draw Order
Cad drawing ?... if so, VG and turn off the layer that has what you don't want.
Masking Region Fill Region Problem
Mon, Mar 10, 2008 at 11:06:24 AM
Masking region at section callout head.
Tue, Jul 30, 2013 at 1:43:26 PM
Draw Order in Family Editor
Wed, Aug 28, 2013 at 3:07:31 PM
Masking/Filled Region Does not work in Roof Plan
Thu, Jun 18, 2009 at 9:18:25 AM
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
Page generation time: 2.2890
