Forums >> Revit Building >> Technical Support >> How to bend my workplane to fit curtain surface... ?
Tue, Feb 24, 2009 at 7:56:53 AM | How to bend my workplane to fit curtain surface... ?
jawii
Hi.
I'm trying to figure out how to "bend" my workplane to fit any given surface.
For example to fit solar panels to a curved roof (pictures)
any ideas / solutions ?
 Thx
jw
Tue, Feb 24, 2009 at 8:03:44 AM | How to bend my workplane to fit curtain surface... ?
4 Stars: 205 Votes
Create those panels in a "Generic Face Based" family...
Tue, Feb 24, 2009 at 8:05:40 AM | How to bend my workplane to fit curtain surface... ?
Obviously a plane is always flat  ... that's why it's called a plane.
Fitting flat surfaces against a curved surface is always a problem ... including in real life.  If these elements are not set to always vertical, maybe you can polar array them if that is an arc that you can define.   Otherwise - adjust them visually to a best fit?
How to hatch the bend
Tue, Jun 17, 2008 at 6:11:32 PM
Duct bend
Tue, Jan 5, 2010 at 11:54:18 PM
Curtain wall on sloped surface
Wed, Jan 7, 2009 at 10:51:56 AM
Surface on solid form getting split after being edited by a void form
Wed, Aug 9, 2017 at 6:28:44 PM
Adjusting the building workplane so that it orients to site bearing.
Tue, Aug 5, 2014 at 7:23:49 AM
Page generation time: 7.8621
