Forums >> Revit Building >> Technical Support >> New windows in an existing wall
Mon, Feb 23, 2009 at 5:25:19 PM | New windows in an existing wall
aaronkennedy
v 2009   I am putting new windows in an existing wall and the windows are appearing as dashed?  Is there a way to make them look regular?
Thank you,
AAron
Tue, Feb 24, 2009 at 5:03:07 AM | New windows in an existing wall
4 Stars: 205 Votes
"Dashed"??? in waht ??? plan, elevation, 3D view????
Tue, Feb 24, 2009 at 6:23:05 AM | New windows in an existing wall
broncos4life
3.5 Stars: 11 Votes
My guess is plan, but it is semantics.  I would start by making sure the phases of each the all and the window are correct.  Then after than see what your phase filter is set to on your paticular view.  Then go look at your different phase filters and be sure they are correct. My guess is that you have it set to a phase filter that has new show as "dashed" or something similar.
HTH
Tue, Feb 24, 2009 at 8:21:55 AM | New windows in an existing wall
aaronkennedy
Sorry for the lack of information on what I was looking at.  Bronco, thanks for your help.  I searched the forum for phases based on what you said and I got it fixed.
Windows and Furred out Walls
Wed, Oct 14, 2009 at 7:47:11 AM
New Windows in Existing Wall
Thu, Nov 10, 2005 at 4:06:18 PM
new wall finish over existing wall
Thu, May 7, 2009 at 10:46:37 AM
New windows in existing wall. Help
Mon, Sep 24, 2007 at 6:02:37 PM
Basic level Q: Wall not cut by window
Tue, Feb 2, 2010 at 10:04:22 AM
Page generation time: 0.6708
