Forums >> Revit Building >> Technical Support >> what are these lines called?
Mon, Feb 23, 2009 at 11:57:23 AM | what are these lines called?
KingRevit
4 Stars: 12 Votes
ok so i'm having a stupid day and can't find the answer to this.
the temporary line that apear when you are placing an object into a project or family that show you when you are lined up with other geogetry, what are they called. they are normally green but i have highlighted them in magenta in the image below.
i want to know so i can figure out how to change them which i guess is done in the ini file
thanks in advance.
Tue, Feb 24, 2009 at 6:29:57 AM | what are these lines called?
broncos4life
3.5 Stars: 11 Votes
What do you want to change about them?  I am trying to think, but I can't think or see of any where in the ini that would change this.  The ini configures your user interface and not system families and system things such as this.  I do not believe there is a way to change them. Not a 100% sure of that though.
Tue, Feb 24, 2009 at 6:53:43 AM | what are these lines called?
qthdad
5 Stars: 2 Votes
I would think that for some, the reason you would need to adjust color settings is due to color blindness.
Tue, Feb 24, 2009 at 8:38:15 AM | what are these lines called?
KingRevit
4 Stars: 12 Votes
hi need to change them for training videos and i would still think that they could be changed by adding an extra line in in ini file just as you do to increase the size of temp dimensions.
cheers
Tue, Feb 24, 2009 at 8:52:04 AM | what are these lines called?
qthdad
5 Stars: 2 Votes
I think they are called Alignment Guides. Specifically, alignment lines and arc extensions.
Tue, Feb 24, 2009 at 11:56:25 AM | what are these lines called?
KingRevit
4 Stars: 12 Votes
hi,
thanks for your input, i have tried both of your suggestions and can't get it too work, i also can't find any reference to Alignment Guides or alignment lines in the revit documentation.
i will send it onto subscription help and see what they come up with
you may have the correct name but it is then shortened in the ini file see below for example
[Graphics]TempDimFontSizeInPoints=12
Tue, Feb 24, 2009 at 1:46:47 PM | what are these lines called?
LIZARD2806
3.5 Stars: 7 Votes
They might also be snap lines.....also not sure, but maybe it will help.
**Using Revit Architecture 2009, 2011, and 2012**
Revit 2008 - changing pattern overscaling color from gray lines to black
Tue, Nov 20, 2007 at 6:25:40 AM
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
Model Lines to Detail Lines???
Sun, Aug 31, 2008 at 9:24:50 PM
Using 2d group for Wall section, section details called out from wall section?
Fri, Oct 9, 2015 at 10:50:56 AM
Spot elevation symbol
Wed, Nov 26, 2008 at 3:04:06 PM
Page generation time: 0.8985
