Forums >> Revit Building >> Technical Support >> Walls Behavior ????
Mon, Feb 23, 2009 at 6:57:31 AM | Walls Behavior ????
cercas
5 Stars: 3 Votes
Hi everybody..
Why does this wall does not show the correct material ???
 Tks
Revit 2009
Edited on: Mon, Feb 23, 2009 at 6:58:16 AM
Joao Cercas
On Revit 2010 (SP3)
Mon, Feb 23, 2009 at 7:33:38 AM | Walls Behavior ????
When you define an element, you assign it a material but the graphics for that material  is controlled by ... settings/materials.
Mon, Feb 23, 2009 at 7:54:35 AM | WWHub
cercas
5 Stars: 3 Votes
Quoting WWHub from 2009-02-23 07:33:38
"When you define an element, you assign it a material but the graphics for that material  is controlled by ... settings/materials."
That is not the problem, the problem is that the material displayed is not the correct one, instead os displaying the plaster material, it's displayng the core material instead....
Joao Cercas
On Revit 2010 (SP3)
Mon, Feb 23, 2009 at 9:19:50 AM | Walls Behavior ????
Revit does what you tell it to do.  Post  a screenshot showing the properties of this wall.  If it is showing the core material, then either you assigned this material to the finish layer or you have no finish layer at all.
Mon, Feb 23, 2009 at 12:08:39 PM | WWHub
cercas
5 Stars: 3 Votes
Quoting WWHub from 2009-02-23 09:19:50
"Revit does what you tell it to do.  Post  a screenshot showing the properties of this wall.  If it is showing the core material, then either you assigned this material to the finish layer or you have no finish layer at all."
Like you ask, as you can see, the wall is showing brick, instead of plaster...
Joao Cercas
On Revit 2010 (SP3)
Mon, Feb 23, 2009 at 12:31:11 PM | Walls Behavior ????
Where is the plaster????  I see brick and I see default ... whatever that is I don't know but it sure isn't plaster..
And how did you get a finish under your structure?
Mon, Feb 23, 2009 at 12:45:04 PM | WWHub
cercas
5 Stars: 3 Votes
Quoting WWHub from 2009-02-23 12:31:11
Sorry, i'm from portugal, and some of the materials are translated.... but you have the file, in the 1º post, with the wall, so you can analyze it better.
Tks
Edited on: Mon, Feb 23, 2009 at 12:45:42 PM
Joao Cercas
On Revit 2010 (SP3)
Tue, Feb 24, 2009 at 5:33:06 AM | Walls Behavior ????
4 Stars: 205 Votes
Cercas, vi a mensagem no RevipPT, explica lá isto melhor....
Tue, Feb 24, 2009 at 6:49:18 AM | Walls Behavior ????
broncos4life
3.5 Stars: 11 Votes
I have opened your attached file and it looks exactly like the picture you posted and so I'm with Hub on this... I dont see where the plaster is suposibly supposed to be.  A print screne should not have any conversion issues.  What layer is supposed to be what?  Layer 1, layer 2...etc.  The file you attached shows the materials correctly.
Tue, Feb 24, 2009 at 9:21:46 PM | Typhoon
cercas
5 Stars: 3 Votes
Quoting Typhoon from 2009-02-24 05:33:06
Se reparares alterei a parede, de modo a ficar como keria, mas em vez de me mostrar a camada de reboco, qd retiro uma camada efault,  por cima dos revestimentos, fica a mostrar-me o tijolo, e nao o reboco....
Edited on: Wed, Feb 25, 2009 at 3:45:55 AM
Joao Cercas
On Revit 2010 (SP3)
Wed, Feb 25, 2009 at 4:17:41 AM | Walls Behavior ????
#11
4 Stars: 205 Votes
Cercas, não tenho aqui o Revit mas o 1º Layer onde tens o material "Default", que material tens assignado?? Reboco ou Tijolo (Brick)?? pela imagem é tijolo, duplica esse material, faz o "Rename" dele e altera para o material que queres, por o que WWhub e o Bronco4life dizem os materiais que tens assignados nas propriedades são aqueles que estão a aparecer na parede da imagem que colocas-te, verifica os materiais outra vez para ver se não à nenhum engano....
Wed, Feb 25, 2009 at 4:57:21 AM | Walls Behavior ????
#12
cercas
5 Stars: 3 Votes
Let's try again....
Joao Cercas
On Revit 2010 (SP3)
Wed, Feb 25, 2009 at 9:25:31 AM | Walls Behavior ????
#13
broncos4life
3.5 Stars: 11 Votes
This is a bug and has yet to be fixed.  Even in 2010.  To make this wall do what you want you should used a stacked wall instead of a basic wall.  This should work.
Wed, Feb 25, 2009 at 11:09:00 AM | broncos4life
#14
cercas
5 Stars: 3 Votes
Quoting broncos4life from 2009-02-25 09:25:31
"This is a bug and has yet to be fixed.  Even in 2010.  To make this wall do what you want you should used a stacked wall instead of a basic wall.  This should work."
Tks, just as i thought ...
Hope to see this fix in the release edition of 2010...Winking
Joao Cercas
On Revit 2010 (SP3)
Curtain wall panels behavior....what gives?
Fri, Jul 22, 2011 at 3:34:54 PM
Curious family behavior on different computers
Sat, Nov 7, 2009 at 12:22:26 PM
Can I replicate the behavior of an dynamic block (autocad) in a revit family?
Fri, Jul 10, 2009 at 10:35:35 AM
Materials in families- weird behavior
Fri, Apr 9, 2010 at 7:14:52 AM
walls with 2 hatches solid/pattern
Thu, Aug 23, 2012 at 7:27:21 AM
Page generation time: 2.1215
