23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Entering numerical value for angle at setting out?
8 Posts No Rating |
Surely there is a simple explanation to this that I am not aware of: When placing walls one can enter numerical values for the distance, but how about the angle? I know I can control the angular increments in the snap settings, but that only gets you so far... How would I best go about achieving specific odd degrees? thnx
After you can place the wall, hightlight it and change the angle.
Yes, revit is more playful then AutoCAD. Place first and then massage as needed to the appropriate shape. Its designed to be quicker on the fly for when designing and then to come back later to set the final angles/lengths etc. As qthdad suggested. Select the wall afterwards to change its angle or add a dimension and change the value of the dimension if you want to change it around a specific pivot point. Once you have 1 wall at the desired angle then any subsequent walls/lines can snap to the angle of this. HTH.
Regards,
Chris.
setting numerical angle for axonometric? |
Fri, Jun 6, 2008 at 12:40:52 PM
SCOPE BOX DOESN'T HAVE GRIPS - ONLY ALLOWS NUMERICAL SIZING |
Sun, Apr 2, 2017 at 6:15:10 PM
Setting Paramtric Rotation Angle for Oval |
Tue, Apr 8, 2008 at 5:15:14 PM
Hatch Pattern Request |
Tue, Feb 16, 2010 at 12:13:58 PM
Rotation angle of double angle roof bracing. |
Mon, Jan 21, 2008 at 2:51:55 PM
