Forums >> Workflow & Implementation >> Worksets >> CENTRAL FILE PATH NOT FOUND HELP HELP!!!
Sat, Feb 21, 2009 at 4:38:34 PM | CENTRAL FILE PATH NOT FOUND HELP HELP!!!
hor4more
OK HERES THE PROBLEM
I HAVE A COLLEGE GROUP OF FRIENDS (3)
-I MADE A CENTRAL FILE IN MY LAPTOP AND MADE A NETWORK
-I CREATED LOCAL FILES ON THEIR COMPUTERS
NOW THE PROBLEM
REVIT SAYS THAT IT CANT FIND THE CENTRAL FILE PATH!! WHEN THEY TRY TO WORK ON THEIR COMPUTERS..BUT I HAVE NO PROB. WORKING IN MY LOCAL FILE SINCE I HAVE THE CENTRAL FILE..
ANY SOLUTIONS ANYONE PLEASE!!!!
Sun, Feb 22, 2009 at 12:35:49 PM | CENTRAL FILE PATH NOT FOUND HELP HELP!!!
robinballew
robinballew Avatar
3 Stars: 4 Votes
if the other users are not connected to your network then they will get that error. You must all be connected to the same network and have access to the central file. If that is not possible then you need to create specific Worksets that you will all check out, become owner ( not borrow )  so that you can work remotely without being connected. Not ideal. You will still have that error but will work at risk.
BallewDesigns.com
Central File Path on a local file
Sat, Oct 24, 2015 at 10:21:20 AM
can't view file properties - central path
Fri, Aug 21, 2009 at 2:34:53 PM
Plot stamp: Set file-path to Central
Tue, Jun 7, 2016 at 8:33:00 AM
Revit on Mac - Parallels - Issues w/ Central File
Thu, Mar 4, 2010 at 3:49:34 PM
File Path in Titleblock
Wed, Nov 10, 2010 at 10:48:55 AM
Page generation time: 0.5439
