8 Users Online (7 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Column Base Plate Nested Family - GCS Visibility
Sat, Feb 21, 2009 at 9:17:59 AM | Column Base Plate Nested Family - GCS Visibility
galambos
I have finally figured out how to attach a nested family base plate with anchor rods to a column in Revit Structure 2009.
However, I came across a problem with the Graphical Column Schedule.  If the anchor rods extend below the lower reference level in the column family, it lowers the bottom of my column graphically in the schedule, as if the anchor rods are a part of the overall column length.
 I have set the visibility of the nested base plate to "Fine" and to only appear in 3D views, but no luck.
I would hate to scrap this after coming this far.  Does anyone have any ideas?
Attaching a footing to a column with a base plate nested into the footing family
Thu, Jul 11, 2019 at 12:23:42 PM
base plate visibility problem
Thu, Dec 1, 2011 at 12:34:33 PM
Column base plate tag units display.
Mon, Nov 17, 2014 at 2:24:40 PM
? Passing parameter values either between hosted families or nested families ?
Tue, Dec 21, 2010 at 2:21:47 PM
Base Plates & Graphical Column Schedules
Mon, Feb 22, 2010 at 11:51:01 AM
Page generation time: 1.1033
