Forums >> Revit Building >> Technical Support >> Attaching sweeps to curtain walls
Fri, Feb 20, 2009 at 8:39:30 AM | Attaching sweeps to curtain walls
djstarr14
So I have my curtain wall, I am trying to attach a sun shading device that i made from a profile. However, sweeps dont want to stick to curtain walls for some reason. Any ideas? I have to install some kind of sunshading device on the wall. just wondering what i can do to make this work?
Fri, Feb 20, 2009 at 9:07:55 AM | Attaching sweeps to curtain walls
If you have a wall above, that can host your sweep ... may have to mess with your profile origin to make sure it resides on the wall.  You can also do a family in place ... or even outside the project.
Fri, Feb 20, 2009 at 11:42:36 AM | Attaching sweeps to curtain walls
djstarr14
The sunshade above the curtain wall in hosted to the wall above. What im having difficulty with is attaching one to the curtain wall portion of the cylinder. It doesnt want to host to it. Is there a work around or maybe a different family i can use that will attach to a curtain wall?
Fri, Feb 20, 2009 at 11:44:19 AM | Attaching sweeps to curtain walls
djstarr14
I am using Revit Architecture 2009
Fri, Feb 20, 2009 at 4:04:27 PM | Attaching sweeps to curtain walls
You just want a sun shade lower than the one you have right?   My answer still applies!
Attaching curtain walls to multiple roofs
Mon, Nov 5, 2012 at 2:19:44 PM
Walls with automatic wall sweeps
Fri, Aug 31, 2012 at 3:58:55 AM
curtain wall top attachement
Thu, Jan 11, 2007 at 12:55:20 PM
Angled Curtain Walls - fillets and nested
Thu, Apr 23, 2009 at 5:42:47 PM
Curtain walls
Mon, Nov 7, 2011 at 10:28:33 AM
Page generation time: 0.4435
