22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Array removing existing parameters
35 Posts No Rating |
I have a sliding stacked 6 panel door that i am wanting to add an integer parameter to for # of panels. I have my one stationary panel on the left and am arraying it to the right. The original panel works fine, all parameters move appropriately, until i array it. Then the Panel width parameter is not satisfied. I need to array the panels in order to be able to specify the # of desired panels. Anything helps... Thanks Stephanie
Is the rough opening supposed to stay constant or is it supposed to change based on panel width and number of panels?
I'm not using Rough Width/Height parameters. I have done some more work on it and re-posted. I think now you can see better what it is that i am trying to accomplish.
I just want to specify # of Panels and Panel Width. Door Width then moves accordingly. But since the array I have no control over my existing parameters: Panel Width, Height
I would suggest making the panel a separate family and embed it.
See if this gets you close to what you need.
Edited on: Sun, Feb 22, 2009 at 7:45:52 AM
By the way, wouldn't you want the door to grow from center, not from one side?
Associated Parameters in Array Family |
Mon, Feb 27, 2017 at 8:44:36 AM
Parametric Array Constraints |
Tue, Jul 2, 2019 at 7:00:45 AM
Polar Array - How to constrain the center location? |
Tue, Nov 19, 2013 at 2:14:44 PM
Variable Length Family with Array Formula |
Wed, Aug 8, 2012 at 9:56:46 AM
Revit array with dissimilar elements? |
Sat, Oct 1, 2011 at 1:03:03 AM
