Forums >> Revit Building >> Technical Support >> Gross Area and labels / shared parameter
Wed, Feb 18, 2009 at 4:33:15 PM | Gross Area and labels / shared parameter
jhemberger
We are setting up a title block on which we would like to show some project parameters (eg: gross area, site area, occupants)  is there any way to pull the gross area number that is generated in an area plan and have a label in a title block family pick it up with a shared parameter?  Can you somehow link a label's parameter in a title block to a schedule that would be created?  Is the gross area a parameter you can export as a shared parameter?Currently we have all these values set up as labels and the number is manually entered.  It seems like this could be done for you.JoshuaUsing Revit 2009
Thu, Feb 19, 2009 at 7:32:19 AM | Gross Area and labels / shared parameter
robinballew
robinballew Avatar
3 Stars: 4 Votes
No need to place it as a lable in the Titleblock.. Just place a schedule with only the information you want. I would make it part of my template so it is there when you start the project. It is not possible to link the area number to a lable in the titleblock. If it is something that needs to be on all titleblocks and you don't want to keep adding the schedule on new titleblocks you will have to manualy add it. Make it a type parameter so at least they will all be the same.
BallewDesigns.com
Creating custom labels showing area in a titleblock.
Wed, Aug 7, 2013 at 10:40:49 AM
IFC export: Gross Area
Fri, May 29, 2009 at 3:01:19 AM
Rentable vs Gross area, gross area in practice
Tue, Mar 13, 2012 at 11:15:27 AM
Schedule Values (SF, Volume, etc) into Labels
Wed, Jul 22, 2015 at 3:13:56 PM
Gross areas & Phasing
Mon, Feb 23, 2015 at 9:14:01 AM
Page generation time: 0.3045
