Forums >> Community >> Newbies >> Don't understand
Wed, Feb 18, 2009 at 12:13:11 PM | Don't understand
TONY121
I just want to insert a door or window opening in my test project but I repeatedly recieve this error message;
Error (must be addressed in order to continue
Instance of 36"x84" not cutting anything
I get this regardless of the size of the opening. I also can not insert vertically. I am new to revit and am learning how to represent my firms drawings so any help would be much appreciated.
Wed, Feb 18, 2009 at 12:41:39 PM | Don't understand
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Put a picture of your model up, do you actually have walls? Are the walls tall enough for them to be cut? Have you established levels more info is needed this is really basic.
Wed, Feb 18, 2009 at 12:42:28 PM | Don't understand
4 Stars: 205 Votes
And that door or window is from????
Wed, Feb 18, 2009 at 1:16:51 PM | Don't understand
I suggest you start with the tutorials that come with REVIT.
Wed, Feb 18, 2009 at 1:19:36 PM | Don't understand
ThatGuy
Hi,
The error just means that the door is not set to the right height for it to intersect the wall or like the others were saying the wall is to short, (but in most cases the door will insert into a half wall) make sure in the properties when inserting the door that it is set to the level you want.
 Hope this helps : )
Wed, Feb 18, 2009 at 1:23:31 PM | Don't understand
TONY121
I think that the problem is I am in structural views trying to insert architectural information. All I need is to represent the openings in the walls. I have all levels set up and 10' walls.  Pic is attached.
Thu, Feb 19, 2009 at 11:12:33 AM | Don't understand
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
It looks to me as though what you have is a AutoCad Drawing not a Revit, You must create all the walls in Revit first. show 3D view, better to read the User's Guide, before jumping in to hard.
Thu, Feb 19, 2009 at 11:31:42 AM | Don't understand
TONY121
No, I have walls, 3d view, elevations, grids and a linked autoCAD view used as a template. I figured out what I was doing wrong.
HELP ME! DOORS?
Tue, Oct 17, 2006 at 11:33:33 AM
BEWARE - Parameters don't update.
Thu, Sep 1, 2005 at 11:36:58 PM
Why some 2 letter shortcuts require enter or space bar and others don't
Tue, Dec 31, 2013 at 10:39:19 AM
''Visibility grafics'' and ''create parts'' problem when mak
Fri, Mar 19, 2021 at 11:45:46 AM
Trimble do's and don't's???
Wed, Apr 30, 2014 at 12:45:45 PM
Page generation time: 0.6151
