Forums >> Revit Building >> Technical Support >> Link within Revit Link
Tue, Feb 17, 2009 at 2:02:41 PM | Link within Revit Link
missalves
This question is for Revit Architecture 2009.  I have a structural model linked into my architectural model (also Revit 2009), and if I go to the visibility/graphics, I see an additional link.  I've seen this in other drawings and the name of it is always a number, but the number varies.  Does anyone know what this is and what it controls?  Thanks.
Mon, Mar 2, 2009 at 5:10:48 PM | Link within Revit Link
corymac82
It may be something that is linked into the structural model?
Wed, Apr 14, 2010 at 9:50:39 AM | Link within Revit Link
bert
It refers to the version of the linked file. 2 means you've linked in the file (1), and reloaded it once. Reload it again, ad it'll say '3'.
Great Revit karma will come to you for answering my many questions.
using RAC-2013
Blog: Revit Templateer
Wed, Apr 14, 2010 at 9:52:54 AM | Link within Revit Link
Not really the number of reloads but the instances.  If you copy the linked file in the project to a new location in the project, you will have another instance.
Edited on: Wed, Apr 14, 2010 at 9:53:22 AM
Wed, Apr 14, 2010 at 11:10:27 AM | Link within Revit Link
bert
I've noticed this number changing with the file being linked in only once (structural file). The number changed every time I reloaded the file.
using RAC-2013
Wed, Apr 14, 2010 at 11:33:42 AM | Link within Revit Link
Something else going on there Bert
Wed, Apr 14, 2010 at 3:55:05 PM | Link within Revit Link
missalves
WWHub is right.  I tried reloading it, unloading and reloading, and even removing and re-inserting, and the number never changed.  But if I copied it, the new copy had a different number under the same heading.  I think it has to do with being able to control the visibility of individual links if you have multiple copies of the same model but each has different graphic overrides (such as a master plan with multiples of the same building, but only showing the annotations from one of them in a plan).
Naming of Architectural Link in Revit Mep
Wed, Dec 18, 2013 at 1:45:37 PM
12
Link Revit File
Tue, Dec 4, 2018 at 11:59:19 PM
Revit Link - Two visual styles displayed in one view
Mon, Nov 12, 2012 at 5:37:21 AM
How to work with the elements from link
Tue, May 27, 2008 at 12:14:43 PM
import/link, manage links...
Tue, Apr 1, 2008 at 11:46:16 AM
Page generation time: 1.4400
